How can I enlarge working space? I deleted buttons but can’t scale the working space.
And how can I return “active points” info, I deleted it by mistake.
Document size for item 1, Should be what you want. If you didn’t save the UI, it should reappear when you open after closing. If you had it saved and it was OK, then Restore Custom UI should work. There are more UI layouts available with buttons at top right. In Preferences:Misc you can find the points to drag back in. http://docs.pixologic.com/getting-started/basic-concepts/the-canvas-document/
Thank’s for answering!
I’d like enlarge the document’s window not the document.
I still can’t enlarge the window for document. Only tab button helps but all my custom buttons hide too.
I want to dispose of the empty space without buttons at the top
The information you want is in that last link…
Maybe the right question is how can I hide a shelf?
Like I hide a tray or menus.
In other ui layout it hides automaticly when I delete all buttons.
The reason is that I add items to the shelf that is above top shelf.
There are two top shelves or maybe there are two highlighted lines and zbrush extands top shelf when I put item in the line higher .
When I put items on lower line of top shelf the higher line hides automatically))
