Custom UI - SYMMETRY always disappeares - SOLVED!
I was hoping it would’ve been fixed but there’s one issue with a UI configuration.
No matter where you place SYMMETRY BUTTONS on your custom UI - and no matter how you save it - it just wont stay.
Every new Start of ZBRUSH it’s gone.
Anyone else got this problem?
See if installing the UIStarter script helps http://www.zbrushcentral.com/showthread.php?160733-ZBrush-4R2-Troubleshooting-FAQ
I have the symmetry controls as a custom UI and have this installed.
If you put a tool in edit mode and toggle the UI back and forth, it should reappear on the UI. I’ve also seen Polycount users recommend the last download at http://www.zbrushcentral.com/showthread.php?160733-ZBrush-4R2-Troubleshooting-FAQ though I’ve never tried it.
Edit: Beaten.
Thanks - will try this out in a minute - its only the SYMMETRY buttons that are missing - everything else stays - hope this plugin will fix it.
Awesome! Thank you! I was having the same issue, symmetry buttons were not being saved but with this script it FINALLY saves in the ui file :)))
SOLVED!
I wish there would be scripts for other issues as well :wink:
