custom Ui problem when i try to move Intensity curve? [Answered]
Hi ,
i just want to ask it’s there a way to fix this :
i did my own custom menu with custom sub palette , i can move anything in my custom sub palette except any Intensity curve, :frowning:
Thanks
Curves can’t be moved in a custom UI. What you can do is assign a hotkey to the curve. It will then pop-up at the cursor. You need to make sure the cursor is open beforehand.
HTH,
