Using a Custom UI Offsets Top Menu Mouse Click
–> When I put my mouse up to use the top menu selections it opens the wrong menu offset 2 menus to the right.
(this happens on home and at work computer, I have Zbrush covering about 3/4 of my monitor space while working)
–> I use a simple custom UI.
–> Instead I have to try to scrub mouse across until it fixes and opens the correct menus.
This did not happen in the previous version.
It is quite bothersome at work , slows workflow consideribly every time you need a top menu item. Any fixes?
