custom UI/empty menus [solved]
So I’m trying to figure out why the menus that I created inside zbrush are now empty. I spent a while setting up the interface the way I want it to be. I created new custom ui/new menus. I saved the ui config just in case zbrush doesn’t store it. Once I loaded zbrush back up, I opened the custom ui config file and it loads all the menus, but they’re all empty. Any ideas why this is the case?
I’ve already downloaded the UIstarter plug, so that shouldn’t be the problem…
Some UI items will not work at all in a custom arrangement. For example, the SubTool and 3D Layer lists. Some other Tool palette items may cause problems. Other palettes should be mostly OK.
figured it out. I usually have a config file saved with each project i’m working on. This time though zbrush would not load it accurately unless I copy and pasted the config file inside the startup folder…
