Hi everyone I have a strange issue in Zbrush. I use a custom menu so I can work faster it has my tools for hard surface. I have always used this menu, even in the studio I work on I changed computers but load my menu with no problem. Today I was working and my menu don´t appear. Just the name with no buttons :evil: but I tried in a coworker and it worked just fine. I am using r5 he is using r6 and the menu works just fine. Even at home it works. I uninstall and re install I tried restore to standard but the menu don´t appear with the buttons. Can someone please help
there´s something wrong with my computer or my zbrush because I did a new menu, work in a character I am doing, saved the UI so zbrush loads it and the same thing happens the menu is there but no buttons :td:
No object in edit mode, no buttons. Applies to ZBrush. Answered this one before today.
That wasn´t the problem, even in object mode the buttons in my menu appeared. I got a script in this forum for a similar problem UISTARTER_Z4R2_V1 and fixed my problem!!
You’re not using ZB4R6 P2?
I am using ZB4R6 don´t know if it is P2. But it solved my problem the file I mention, all my custom menus now appear
thanks for the help!!
Should be stated right up where you see ZB4R6. If not, go to ZPlugin:Auto Update
never looked at that button " Auto Update " :o thanks
