Hi, i’ve created custom menu, and assigned hotkey for it. I have question, on one tutorial i saw that guy have cutsom menu with subpalettes, and them was expanded by default. In my menu i have to click on subpalette name to expand it. How make subpalettes expanded by default?
Go to “Preferences > Interface > Palettes” and turn off “Auto Collapse” and “One Open Subpalette” buttons.
You may also want to use UI Groups but prevent them from auto-collapsing. UI Groups are basically subpalettes within subpalettes. Go to “Preferences > Interface > UI Groups” and turn on “Use UI Groups” button and turn off “AutoClose UI Groups” button.
If you want these settings to remain every time you start ZBrush, you have to save the configuration. If you don’t know how, you can press “Ctrl+Shift+I” or go to “Preferences > Config” and click “Store Config” button.
Done;)
Thanks! Was facing the same issue
