Custom keyboard shortcut for Deformation Pallet?
I want to make a custom keystroke for opening up a sub pallet like ‘Deformation’ without messing up the standard interface too much. Preferably ‘CTRL T’ to make it a similar keystroke to photoshop. Although Zbrush seems to accept the customisation by the recommended CTRL/ALT technique nothing seems to happen when I try to use it. This does work however if I want to assign functions further down the pallet like ‘size’ instead.
Also having a similar problem with the mouse wheel which I’m attempting to set as brush size, but all it does is alter the highlight on the number.
'hope someone can help?
I don’t know of anyway to do this. Maybe someone with some crazy scripting knowledge may know more
The easier route may be to create your own custom palate/menu and copy in the elements from the Deformation palate that you want. You could then hotkey that palate.
Creating your own palate/menu
http://docs.pixologic.com/user-guide/customizing-zbrush/interface-layout/custom-interface/
https://www.youtube.com/watch?v=-oTAllGY8DY#t=27
https://www.youtube.com/watch?v=ZYLy8vK4Np4
I put a couple of the items from the Deformation palette in my custom UI setup. Files at below link.
