Hi all. I have been using curve surface brush in previous Zbrush versions and it worked fine but now it is impossible to move end or start points of the curve alone in R5 version. I tried all the settings ‘‘Lock Start’’ ‘‘Lock End’’ but I still cant move these points alone. Whatever I do the whole curve is moving. Bend modifier helps but it gives a bit different effect. All I want is to just be able to move the end point or the start poin alone.
