Hello
I have some questions on the great new brush curve tube.
First is it possible to edit the curve without reapplying your size falloff. I explain : I have edit the size falloff to have a great tapering effect at the start and end of the curve. I create my curve but I want to edit the path. When I click on the path to adjust it, the tapering effect is applied at this precise point. THre solution I found, was to click at the end of the curve, once iut was edited, to reactive a correct size tapering. IS there a better way to do it, a way to edit curve without reapplying the size falloff ?
2nd question is there a way to put a diiferent form as base for the extruding along the path. By defaut it is a cylinder as it is creating a tube. I would try to use it to make, for example, a cube extruding along a path or any other form. I don’t think it’s possible, but I ask, we never know
Thanks
Vincent
