Curve multitube tutorials needed
I’m curious if anyone is creating any good tuts on using this brush. It feel like it could be very helpful, but not sure how to get it to do what I want it to do. Also if you want to taper these curves, how do you change the brush settings?
I initially gave you the wrong information. Sorry. The correct information to your question is as follows.
  1. Select the ‘CurveMultiTube’ brush.
  2. Go to Brush>Modifiers and change ‘Mode’ to 0.
  3. Go to Stroke>Curve Mode section and turn off ‘Bend’ and ‘Intensity’ and enable ‘Size’ only.
  4. In the Stroke>Curve Mode section, modify the ‘Curve Falloff’ curve to change the shape of the tubes.
If you want to edit the curve line after you draw it, enable ‘Bend’ in the Stroke>Curve Mode section. Having ‘Bend’ off will allow you to move the whole line/tube at once.
Glad I could help! :rolleyes:
