Curve Bridge - straight Line?
How to make a straight Bridge
Is there a combination of settings to get a straight bridge?
Not sure. Tried it a couple times only. Looks easy enough to fix though.
I know if the shape were created using Silo, or Maya, it’s a non issue.
What are your suggestions to fix it inside ZBrush?
B,M,V. small brush size, disable axis if/as necessary, shift points.
mask the points that are in question, or all that you want to be planar.
invert your selection.
use the transpose line to flatten out the plane and move back into position.
