I accidently pressed ctrl f and cant figure out to how undo it, tried clearing the layer but nothing happens. All the subdivs are there and i can rotate it but the material wont show.
what should i do?
what should i do?
If you’ve cleared the layer (Ctrl+N) and the Edit button is on, press ‘F’ to center your model. Then switch off Edit and switch on Move mode so that the Gyro shows. Make sure RGB Intensity and Z Intensity are both at 100. Then switch Edit back on.
If the Edit button is off, make sure the model is selected in the Tool palette then draw on the canvas and then press ‘T’ to enter Edit mode.
Problem solved! I turned off edit then pressed mrgb then turned on edit again. big thanx to marcus who got me on the right track!
