I’ve done it often before without problems : duplicating a mesh by drawing out an action line and then CTRL-clicking the white middle circle.
But now I have created a shadowbox mesh and want to duplicate it, but it gets only moved when I ctrl-click the middle circle, not duplicated.
So I restarted ZBrush and tried it with the “DefaultSphere.ZPR” in the Project folder, and duplicating also does not work on that default sphere.
It does work on other geometry like the “DefaultDynaWax64.ZPR”, but not on the geometry I’ve created, or on the “DefaultSphere.ZPR”.
Is this some kind of bug maybe?
Thanks for your help …
EDIT : SOLVED : I had multiple subdivision levels and after deleting the lower subd levels the duplication worked!
