Creature Question
I wanted to know if anyone could give me advice on tackling a monster with more then one head in zbrush. I was thinking of modeling a Cimaera and not really sure how to go about it. Should I make the heads separate then bring them in or make the Multi heads with z-spheres and if I do start off with all the heads on there how to I scult each head symmetriclly? Is there a way to change the symmetrical axis in zbrush?
If you have to use sym your best bet is to model each head independently. While you can change the axis of sym in Zbrush it can’t be placed on an arbitrary axis. You only have X,Y, or Z.
Hope that helps.
It did that confirms that I need to model it in pieces,thanks!
