Creating Tiled Repeating Texture In Photoshop
Hello:
Please i need to know , How can i apply a texture over an unwrap uv model and paste it in photoshop to adjust over the unwrap model?
Where i can get a good tutorial that explain all the points that combine the texture from z and the way to open, paste, copy…in photoshop?
thanks very much for your time.
Hello,
You cant create a texture from an unwrapped model. The UVs will be all over the place and the 2d image will be scattered. You can texture a madel in Zbrush that has no UV map. You just wont be able to create a 2-d texture from it until you unwrap it.
If you are wanting to edit a texture you made in ZB you need to select the model, goto tool-texture-clone. The texture will then appear in the texture palette. From there you can export it and open the exported file in PS.
I think what you want to use is Spotlight maybe?
