Hi Cwahl
That’s was that !
The moment “pressing the make 3D button” was not signify
All is clear now!
Pilou
ps because I had very often used this button, I was confused to not see it on the text
An extension of the techniques ron and I discussed yesterday, here’s a quick stab at feathers/scales:
A few other things we worked out; using the ‘m’ hotkey to mark makes drawing out your objects incredibly fast. You quickly work up a rhythm of drag, m, drag, m, drag, m etc…
The other thing, which isn’t strictly needed, is you put your base object on one layer, and do your hair/feathers on another. That way your base object is protected, allowing you to try several approaches if need be.
-matt
Hey Matt.
Good to know there’s a shortcut for marking.
The ‘M’ key. Derrr…I should have known. :rolleyes:
That’s an interesting armoured look you have going there. It’s obvious that this is not just a process for making hair.
Ron- A bit of friendly competition’s always good.
Results from Alpha-Skinning using the ‘Double-sided’ option.
Alpha Skinning = Make3D
Pilou
Thank you for sharing, although I don’t make hair often, this could be an interesting method for creating grass and other types of plants. If I can knock something out, I’ll post an image. Keep up the experimenting!
Hi mestela, that image looks like the one I saw on evasion|3D site look at meshpaint gallery and see what I mean.
See ya,
Jinxius.
Heh, so it does:
Their gallery is a great source of ideas:
http://www.evasion3d.com/mp_gallery.html
Thanks for the link!
Cheers,
-matt
I love what you two are doing and i been trying to get the hang of it. I’m still pretty newb at this as i am not the best at experimentation.
So, i got 3 questions
- where do i find the Optimize button?
- how do you get the hair to taper near the ends like that? My attempts don’t seem to do that.
last one, - When you guys style it with deformations are you using the gyro or clicking edit?
Forlocks,
thats a pretty old thread - we havent heard from Cwahl in a while.
heres a thread with a zscript he posted to make this kind of hair.
http://www.zbrushcentral.com/zbc/showthread.php?p=40704#post40704
Optimize is in the the geometry section of the tool pallette -
I think this hair was figured out in 1.5b from reading the threads -so there might be slight procedural differences.
Deformations is in the tool pallette too
H
Excelente manera de resolver el pelo cwahl
can u anybody tell me how to do the alpha stoke
i guess im the only person that cant do this tutorial for strands of hair… i just dont really follow any of it…
“making dots uniform”?
“alpha shin with mesh with smoothness at 1?”
i dont suppose you could dumb it down a little more or maybe even just make a simple video?
- Choose the Tool>SingleLayerBrush and the Spray stroke type. I also recommend Alpha 14 for its hard edges. I use the single layer brush because it allows you to adjust RGB intensity and Z intensity separately.
- When you have the Spray stroke type selected, go to the Stroke palette. There you will find settings that affect the stroke. Set Placement to 1, Flow to .25 and Scale to 1.
- Set Rgb Intensity to 100 and Z Intensity to 2.
- On a blank canvas, use a couple very brief strokes to create your alpha. It should a pattern somewhat similar to the Spray stroke’s icon – fairly round if you want just a lock of hair. Of course, if you wanted a layer of hair you could create a line of scattered dots instead.
- Select the MRGBZGrabber tool. Drag a stroke on the canvas that boxes in the alpha that you just painted. When you release the mouse, you’ll have a new item in the Alpha palette called DepthGrab01.
- Now that you have your custom alpha, you can clear the canvas. If you want, you can create more alphas as long as you have everything set up for it.
- Make sure your custom alpha is selected. In the Alpha palette, set MRes to 256, MDep to 100 and MSm to 1. Turn off DblS. Now click the Make 3D button (which is right next to those modifiers). A quick message will appear, then a new tool will appear in the Tool palette. This is a 3D mesh created from your 2D alpha. It will become your hair.
- Draw the new mesh on the canvas and enter edit mode. Rotate the view a bit so you can see what’s going on.
- In Tool>Deformation, turn off the X and Y modifiers next to Size. Only Z should be active. Now repeatedly set the deformation to 100. Your hair tool will double in length each time. After several such deformations, it’ll look like a lock of hair.
Don’t want every hair in the strand to be the same length? Try this: Before you convert the alpha to a 3D mesh, increase the Alpha>Rf (radial fade) setting slightly. Values of 2-5 should be ideal. Then press Make Modified Alpha to convert that setting into a new alpha. The resulting 3D mesh will have the longest strands in the center.
Cool walk through aurick
Good to see that the latest Zbrush has ways to make this technique even more effective. Thanks Aurick!
