creating a repeatable deformation
If I had a square image that features a symbol at its center. and i wanted to repeat that tile along the edge of something cylindrical what technique should i use?
ive tried using radial symmetry and also tried using projection master which both produce artifacts on the sides. and the stitch brush produces less than desirable results.
Maybe if you showed the problems you were encountering, it would be easier to help find an answer.
Also, did you see http://www.zbrushcentral.com/zbc/showthread.php?t=70281
i think i have it worked out… i used drag dot with radial symmetry. and it also seemed to help when i had mirrored turned off in the symmetry tab
