Crease brush problem found
HI! when using crease brush to create crease edge, IF the z-intensity not ZERO,the crease brush became a CLIP brush and will not make any crease edge …
instead, i try to use trim brush(it will make sharp cutting edge and new polygon) + crease polygroup border, but trim brush just not exactly the same as clip brush(because it just delete the mesh and cap hole,but what clip brush do is push the mesh in)…
1–when intensity=0:
2–when intensity > 0:
