I am sure this has been asked i’ve tried it on multiple machines. Run diagnostics etc. Machine wise good high end, drivers all are up to date.
Crashing happens frequently both 4r7 and 4r8 with the deformation tab “only”. After so many uses of only the deformation tab it does crash. Also with 4r8 I am seeing crashes if i load between project files, with zbrush open. So many projects between when loading a new one crashes occasionally, none of the other features seem to cause it to crash it works fine with a very dense mesh. Any suggestions would be greatly appreciated thanks!
