Crash when using imported alpha map for displacment
Greetings,
ZBrush for Mac OS X crashes when I try to us an imported alpha map for displacement. It works with the built in alphas.
Maybe something is wrong with the format?
I am using a 512x512 grayscale bmp with one layer.
Thanks
Try using a 16-bit Grayscale PSD instead of bitmap.
I discovered the problem was not the format.
My alpha maps work if I put them in the Alphas folder so that they are in the Startup Alphas palette.
Using an imported ones for displacement cause a crash.
So it is a bug.
Could you please open a Support ticket and provide step-by-step instructions to duplicate this?
