Crash on save of tool
Hi I am sure this question has been asked before. (If so please post thread link and this thread can die before starting)
I often get re-occuring crashes upon saving my ztl tools (different tools- differint topology -all quads) - I usually go down to my lowest subdivision and save, but Zbrush sometimes still seems to fall over on saving.
Any suggestions (And yes this is a legit version of Zbrush).
I suppose this could be a system spec memory managment issue?
Cheers
jake
  1. Don’t press Ctrl+S to save with the PC version. Press Tool>Save As instead.
  2. Better still, use the Save button found in SubTool Master. (If you don’t have it yet, check the Download Center in my signature.) It has special routines to help avoid these kinds of problems.
Cheers Aurick
Will use subtool master (Which I do use and is great) save from now on and see if that resolves the issue.
