couple of questions for yall
1- when i try to load a .ZTL in zbrush 3.1 made in zbrush 4 the 3.1 does not let me , so i think 4.0 .ztl format is not readable in older versions . so is tehre a way to get some Z4 brushes to work in Z3.1
2-Zmapper is the greatest , why did you went ahead and made the new ones without it , i cant render a single normal map made in Z4 (using maya mental ray) and i know the steps to do so , it just renders black or does render ,but with awful seams on the uv borders.Can i ask you to make a Zmapper in zbrush 4 so i dont need to figure out impossible ways to export my details as a .obj from Z4 and wait to load 3 minutes in Z3.1 so i can Z mapper it .
just imagine how bad not having vital z mapper plug in in Z4 is for me and others , i hope i get some repplies .
Ok ignore me :frowning:
i got a littlehelp from a good friend , and now i use xNormal to generate my maps so thanks for the silence , i hope to get my started models finished finally :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
