Hi Marcus, thanks a lot for your tip.
The thing is, that with the sliders you cannot reach the very exact position.
I found another way, what works perfect, but is a bit complicated and needs another software, in my case Cinema4D, and GoZ:
Requirement: There are two meshes with exactly the same point/poly number, but different shapes. I call them »original« and »target«
Export the original via GoZ to C4D
Delete the original (subtool) in ZBrush
Target mesh: store Morph Target
Export the original back to ZB from C4d
This comes to, that the deleted original reappears again
Delete the original once more
Rename the target mesh with the name of the original
IMPORT the original mesh to the target from the User=>for all users=>pixologic=>GoZProjects=>Default-folder (there you will find a .obj)
This will import the original mesh exactly to the old position. As you stored a Morph Target, now you can switch between the two shapes.
Got it?
Viele Grüße,
Stephan
