controling draw size
I use the [] keys to control the draw size of my brush. This allows the brush to change from 5 to 15 to 25, and so on. I was wondering if there’s a way to change this increment to something smaller, like say 2 or three, rather than ten(way too big). Is this possible? I know I can use “s” to bring up the draw size tool, but the way I use the keyboard layout makes it way more convenient to use the [] keys. Thanks!
I wrote a little plugin which allows you to change the increment thru a slider. See here:
http://www.zbrushcentral.com/zbc/showpost.php?p=371707&postcount=8
If after installing you look in the ZPlugin>Misc Utilities submenu you will find a couple of new buttons: Br<< and Br>> and a slider Br_Amt. Set the slider to the increment you want - though note whenever the brush size is below 10 it will change in units of 1. Also you may need to set the hotkeys for the new buttons so that they override the originals - Ctrl+click on a button and then press ‘[’ or ‘]’, storing the hotkeys before exiting ZBrush.
Holy cow. Thank you! You do realize how much this is going to help my work flow? I think I’m gonna cry. :cry:
