Ok … So i’m working on the most basic tool, a Cube. It’s a 3D polygon object with just 2 levels. Edit and Draw are on and I want to paint a mask. I hold down the Cmd (Control on PC) key and start to paint. Heres the question, every time I hit the Cmd key my “Brush” and “Stroke” switch to “MaskPen” and “FreeHand”. What’s up with that ???
is default setting , if you hold the ctrl key then you can select your choice in both of them
