Constrain to 90 degrees Not Working (Shift+Click shortcut)
Hey! I’m slightly new to the forum, and I figured I needed some help on here.
For some reason, Shift + Click (to orientate the model to the nearest 90 degrees axis) isn’t working under the Edit and Draw Mode when I’m working with Zspheres. But it works for Edit and Move, and Edit and Rotation, and Edit and Scale combination modes. But the shortcut/hotkey also works for Edit and Draw Mode for a polymesh model.
So for some reason I can’t easily rotate my zsphere model to front, back, or side under Edit and Draw modes.
Instead, what happens is that part of the Zsphere that I’ve clicked on, kind of disappears. Or actually, I think it sinks into itself. Because when I try to preview adaptive skin once that happens, Zbrush 4 crashes. (I know that in order to handle “holes” in the Zsphere model, you have to use classic skinning.)
Is this normal? Thanks to anyone who replies/figures out a solution.
(I use a Macbook Pro… if that changes anything. o.o; )
It might be the mac thing. I just tested it on a pc and it works fine. Just a thought, though. Try hitting A to go into adaptive skin preview and see if it works while in that mode.
