Hi all, like write in the title, i would know if is possible when you use curve brush, after you draw the curve on the mesh, move the curve draw horizontal or vertical (maybe with shift or alt click).
Hope you understand me.
Bye
Leo
That will only work if you are using a straight line curve. Enable "AsLine’ in the Stroke palette. Using ‘Shift’ key, you can constrain the line to horizontal, vertical or 45 degrees.
i know this, when you draw the (curve) line with shift and then you move this one to paint or sculpt around , i’m not able to costraint…
