Hi everyone,
So I’ve tried looking on the forums here and whatever tutorials I could find.
Here’s what I’m confused about:
I understand that the material swatch determines what base material will be applied to your model and the color swatch allows you to choose the colors you’d like to paint on your model.
What I don’t understand is how to paint something white!? For example I chose the Reflected Red material as my base material. When I paint different colors on top of it it works great except for when I choose white. It seems like white just means no color. When I paint using white it looks like it just erases whatever other color I’ve painted to allow the base material I applied to show through.
If this is the case does it mean I need to start with a white base material if i want any part of my model to actually be white?
Also what if I like using the Reflected Red material as my base material because of its properties…can I still change it’s color to white ?
I don’t see anything under the Material-Modifiers menu that lets me change the color to white…
If this is possible does it create a new material or change the properties of original Reflected Red material that comes with zbrush? Obviously I’d want to create a new material and not mess up the original.
