Confused about ZProject
I seem to be having problem with using ZProject to put texture onto my model.
I have an image which is a front & side views of someone’s face that I imported. I draw my Ztool onto the screen, set it facing front and enter edit mode.
I go to the move tool to select where to take the texture from and where I want it to go to on my model (ztool).
I go back to Draw mode but instead of it taking the texture from the point I picked , it is taking in from the image directly under where I am painting.
Is this a simple nooby thing I have done wrong because the video I saw seemed to make it looked so easy.
Any helpful tips gratefully received.
I guess your are using v3.5r3? I’ve noticed the change to the way that zProject works as well. Looks like it either is broken or it’s been purposefully changed. Here are a couple of threads I found that mention the same thing
http://www.zbrushcentral.com/showthread.php?t=78194
http://www.zbrushcentral.com/showthread.php?t=80613
Yes, I am in 3.5 R3. Well at least I know I’m not going lala now. Thanks for the reply.
