I have a mesh that I split into two subtools A and B and saved this 1st .ztl file. I did some more work on one of the subtools A and saved again but had deleted the other subtool B then saved a 2nd .ztl file. What would be the best method to retrieve the subtool from the 1st .ztl file and bring it into the 2nd .ztl file. I would like them to be in the same place relative to each other as before. I have managed to use an insert brush and then having loaded 1st.ztl file using the Insert Sphere but picking the 2nd .ztl with the correct version of A in. I find it hard to align to the original
The only method I can think of is to export both into 3ds max through GoZ or exporting .objs and combining there then re-exporting back through GoZ or saving.
Thanks for any advice.
