Coloring and adding material to Subtools?
Hi I’m just starting and have seen the tutorials on zClassroom, but I can’t figure out how to color and add material to multiple subtools without changing the other MRGB information on the other subtools. I’ve tried Fill Object but that doesn’t really help.
Did you active “Polypaint” before starting painting a subtool ?
It’s the same steps as here: http://www.pixologic.com/docs/index.php/Materials_and_SubTools except that you use Rgb instead of M. Or Mrgb for both color and material.
You must fill each SubTool individually. Or you could simply use SubTool Master. (See the Download Center in my signature.)
Wow thanks! you both are awesome. I looked at the site and that did solve my problem, just curious though. To Florencepalpillon, what did you mean by “activate polypainting”?
