Hello, I’ve followed a video tutorial by digital tutors, they explain every step for making a poly paint in zbrush. I’m currently trying to make the color into texture, however when I click on that button, my sculpture disappears, I have RGB at 100, also I have UV on and colorize. As soon as I press Texture to Color, the object appears again. I made the model with Zpherers.
I can actually export the texture to bmp (even if is not visible) and the result will a black BMP. I’ve also exported the OBJ and the MAP into 3ds max, and thats what I get (A black map)
I’ve attached my ZTOOL, in case somebody wants to give it a go and check if I’m the only one getting this issue.
Zbrush>
ZTOOL>
http://www.mediafire.com/file/ovyymntwmqj/PM3D_arbol#6.zip
