I seem to be having problems when doing this as of late. I quit messing with Zbrush for a while - but basically. I Turn on Colorize turn off UV turn off zadd and paint and all goes well until I have to export the texture. I turn on UV with textures off and make sure my sculpt is divided 5 times or so. Goto texture set the size to 1000x1000 and click new. Then Col>Txr and I either get no texture (completely blank) or a very low quality version that’s all pixelly in the size I asked for. What am I doing wrong?
that was confusing…can you show some pictures of what you’re doing?
make sure RGB is on and at 100 when you press col>txr…I think that might work for you…maybe.
Sorry, I know it was rather confusing.
Basically I just want to poly paint and get the texture. Also if there’s a way I’d like to have an option to get the texture and the material used.
Any help appreciated. Thanks.
pictures?
Sorry about that. Edited.
