Whenever i use clipcurve its very uncomfortable due to 5 degree jumps it does when i try to target at the right angle… Is there a way to change it?
it will 5 degree jumps ONLY IF you hold down shift,you can release shift and alt when the “clip curve line” is showing.
For all Seleccitions, Masks, Curves, trims etc. When it is active you can release all keys in the keyboard and draw freely.
While Shift is pressed curves will keep that angle snap of 5º
With Ctrl you can switch to selectRect mode
With Alt you can create curve anchor and double Atl will create point angle anchor
With Spacebar you can transpose to other place
Ahh thanks a lot
Now i feel stupid
