Clip Curve Brush incremental snapping (solved)
Is there a way to stop the Clip Curve Brush from snapping to 5 deg. increments. Trying to place a cut exactly where you want is difficult and can be a bit annoying at times.
Once you’ve started drawing a curve you can let go the Ctrl and Shift keys. That stops the constraints (the Shift key).
Also:
  • Two Alt clicks will make a sharp angle.
  • Press the spacebar to move the whole curve. This is useful if you want to (for example) use an image loaded into Spotlight as a guide.
What a relief…that’s much better…Thanks marcus :slight_smile: :+1:
