Clip Brush
Hi can the clip brush punch a hole right throught the mesh right in the middle ?
when I try it, it just seems to merge the polys in that area…
Simple answer…no.
If you want a mesh with a hole you can create it in Shadowbox. The Clip brushes however will clean up an existing hole.
play with the Ctrl … and Alt
this brush has lots of difficulty with radial symmetry on as well
