Is there a way to clamp radial symmetry to non cylindrical objects such as this?
Looks like you want X and Z turned on.
Then duplicate. Rotate. Then weld.
Make sure you delete the left and right side first. Keep the front and back.
Ignore this…I would delete the post if I knew how. Im basically sculpting it from a cylinder…then il tweak.
