I have to come back with a old issue, discussed 3 years ago, but the work around does not work for me…
I have a 3 monitor setup, 2 “standard” monitors and a Cintiq 21 UX in the middle.
I use a wacom intous 3 to switch between the 3 monitors. If I paint with the Intous 3 everything works fine.
If I paint with the Cintiq 21 UX, the ADD brush mode acts like SUB and vice versa. If I press SHIFT and paint, the model gets sharper…
First I set the Cintiq as the primary monitor, but that does not work for me. Then I unplugged the 2 “standard” monitors and restarted only with the Cintiq, but I had the same problem again.
Here is the link to the old post:
http://www.zbrushcentral.com/showthread.php?73181-Cintiq-21-ux-Issue-Inverted-Sub-Add-brush-mode
- Windows 7 Professional on a Boot Camp Mac.
- ZBrush 4R4
- Newest wacom driver: 6.3.3-4
UPDATE:
I found out something: When I go to “start -> all programs -> wacom tablett -> wacom tablett presetting file Utility”, there I klick “My presets -> Remove”. Now I have to redo some settings (Middle and right klick on the pen buttons and so on) and the issue is SOLVED. BUT: When I restart zBrush it’s messed up again. I saved my Settings, so I just have to reload them. But I really don’t want to reload my wacom setting every time I start zBrush…
Does anybody had the same issue?
Many Thanks!
