CINEMA 4D 10 Normal map -cavity map - bum map
Hi
Someone can share a video or very good pdf and tell me and us how we can do in cinema 4d 10 the normals map, cavity map and bump map (no displace map). I try and try and don´t have a real succes and not is problem from flip the normal map.
Please share a good video mov o flv… because see is better than read :wink:
thx a lot of for a little bit of your time, because i m sure if you know the good way you do it in 5 minutos and me 3 days with red bull all the nights :wink:
anyone can help me… where we put the normal map /cavity map from zmapper to cinema 4d ???
In your material editor in C4d, put your bump map in the bump channel,
cavity map in the diffuse channel, and normal map in the normal channel. See the attached picture. I hope this helps.
thank you… is perfect… i ll try at my home
