Changing to 'best render' causes ZBrush to become unusable.
Hey all,
I am doing some 2.5d work to create game textures. When I switch to ‘Render > Best’ ZBrush becomes unusable/buggy, I can’t interact with any buttons or functions. Any suggestions on how to fix this?
UPDATE:
So I can’t see zbrush responding but when I alt+tab out then back into Zbrush it updates visually to reflect the changes I made or buttons I pressed. Essentially, Zbrush’s display/UI isn’t rendering correctly after I try a best render.
Do you have a custom interface? Also which version of ZBrush and which platform & OS are you using?
No, I don’t. I tried to initialize ZBrush as well. Still having this issue. I was working fine for about 5 minutes then started acting funky. I have to save the tools and document then restart. Any help would be appreciated.
My setup:
i7 4790k
16gb ddr3 ram
GTX 970 (latest drivers)
Windows 8.1 64bit
ZBrush 4R7 P3 64bit
Hmm, I’ve no other ideas. Is it essential you use Best render? If you’re not using materials that need Best then I wrote a plugin that will create a 3D version of the canvas so you could use BPR for a better quality render:
http://www.zbrushcentral.com/showthread.php?172391-Useful-small-ZScripts-and-Macros-for-ZBrush-4R6&p=979836&viewfull=1#post979836
Otherwise I think you should probably submit a ticket to Support. They may have come across this issue before and be able to offer a solution.
