Hello!
I have been setting up a whole new UI in Zbrush 4 r2 and would like to swap the default menu that appears when you hold space bar for a custom menu that I have created. After setting the hotkey (it says it saved the hotkey successfully) the standard menu still appears.
I am hoping someone can tell me how to change/modify/ or better overwrite the SPACEBAR menu. It seems with other key stroke hotkeys I can change them to something new no problem - just not this one for some reason. I have dug around and am coming up blank.
Thanks!
