hi all
I’m new in this community and quite new with ZBrush
I watched some tutorial and everything worked fine with my previous works. It happened now that I can
controll only the material of my first subtool (I mean clicking color-> fill object). For all the other subtools (ie 2 polysphere, a plane3D and 3 different fibermeshes) it is automatically applied the material which I select in the menu on the left (under brushes, strokes, alphas etc). This only happends on this current tool. I don’t have this problem if I load other tools
oh, and this happens regardless if I select MRgb, Rgb or M…
Can you explain to me what happened and how can i fix this.
thank you very much, and I hope I’m in the right section of the forum
ciao!
