Changing GoZ files (shelf_GoZbrush.Mel file)
Hello.
Why can’t I change the paths to the “GoZbrush.xpm” files or the source path (-command “source “/Users/Shared/Pixologic/GoZApps/Maya/GoZBrushFromMaya.mel”\r”), inside the “shelf_GoZBrush.mel”?
I’m trying to change it to “Users/Shared/Pixologic/GoZApps/Maya_2013” but it always reverts back on its original code.
Thx.
Is Maya running while trying to change it?
You’re right. I went ahead and changed both without them running and both the .xpm files kept the changes. The GoZ shelves show up fine now.
Thx.
But now Zbrush crashes when importing from either version. I’ve tried to force reinstall GoZ for both but I get a message saying there are permissions issues or I may need to be logged in as Administrator (which I already am in).
The only thing different about the Maya 2013 install is that I’m using a python script (that was working fine) called “mabackward.py” I got from here: http://www.scaphandrier.net/treex/dev/maBackward.zip.
I don’t get it.
