Changing document size issue - small render?
Hi -
When I change my document size to 4096 and redraw my model, then frame it to my liking and do a BPR render, the model comes out small. The document size is correct, but the actual render of the mesh is small in the center of the document. It’s framed perfectly fine in the canvas window so I don’t know what the issue could be?
Thanks
If the document is displayed at actual size then it can extend beyond the edges of the visible canvas. You need to click+drag the Document>Zoom button so you can see all of the document before framing the mesh. You will then be sure that what you see is what you get in the exported image. Zooming the document doesn’t affect the output size.
this was it! thanks!!
