Changing Brush Size By Touchstrips
Hello there!
I like to use my tablet’s touchstrip to control the brush size,i have assigned “[” and “]” to the touchstrip,but i found it cant be very precision because every step is 10 units.
so is there any way can change the step size?
thanks in advace.
Tim
You could create your own plugin that increments the draw size by whatever value you’d like and assigns your preferred hotkeys. Once that’s loaded into ZBrush you can assign the Wacom settings.
thank you aurick,im unable to make such script,but i found one just what i need!
http://www.zbrushcentral.com/zbc/showpost.php?p=371707&postcount=8
