Change the default folders
Hi! Is there a way to change some of the default folders in zBrush. Let say I want ot hook a plugin from the netowrk, can I add a network path (//network/myplugins) instead of placing the plugin in zstartup/zplugs folder? Same for alphas, material and texture, if we want to share a network directory for texture and alpha in lightbox is it possible?
Thanks!
Oly
If it was in a studio and you had multiple seats, should be possible, you can add short cuts to folders. I could be wrong…
Thanks that work for lightbox, but can’t get it to work with plugins
What I fail to understand is why you can’t just copy the files to where they’re needed? Is someone continually updating them? File management shouldn’t be a problem. :frowning:
Because i’m in a studio and when I do new version of an in house plugin I need to send everyone a copy of it and they need to place it manually… Just want to make update live like we do with maya.
I kinda found a way tho… I just add an arg in the shortcut with the plugin path. It works, but there is a little update bug when you customize the buttons of the plugins in the UI. The customized buttons only appear when you hit the plugin menu. SO if there is another way I would take it.
Thanks
