Change Quick Save Directory?
Does anyone know how to change the quick save directory? Is this even possible?
I’ve run into a problem where I’m running low on space on my C drive which is a smaller SSD. It’s my own fault and I should have made the partition larger. I was working this afternoon and noticed that I nearly ran out of space, down to about 230MB on the C drive from roughly 4.8 GB prior to ZBrushing.
I have ZBrush installed on an entirely different hard drive with a ton of space on it, but it dumps all the quick saves into C:\Users\Public\Documents\ZBrushData.
I set up my Scratch Disk to direct it to R:\ZBrush 4R6\ZData\ScratchDisk to avoid running out of space on the C drive when ZBrush pages to disk. Is there any way to force the Quick Save into a different location, such as the folder within my ZBrush directory? For example, something like “R:\ZBrush 4R6\ZData\QuickSave”
http://www.zbrushcentral.com/showthread.php?187815-ZBrush-Quick-Save&p=1095803&viewfull=1#post1095803
I sometimes empty the Quicksave folder, it isn’t hard to do.
Thanks guys. Not the answer I was hoping for, but I guess I’ll find a workaround.
I’ve got my SSD partitioned with half games / half OS. I was considering getting another SSD since they’re getting cheaper. Maybe I’ll just dedicate one to each.
