Center transpose line?
Is it possible to center the transpose tool on the subtool or whatever is visible?
And is it possible to make the transpose tool follow to the same position after using it?
http://docs.pixologic.com/user-guide/3d-modeling/posing-your-model/transpose/action-line/
No help there to the questions I had?
I don’t mean to move it around manually, but a button to center it on the subtool or whatever is visible.
Hmm, much info there. You read it all and it was of no help? Sorry, there isn’t a button that I’m aware of.
I think they said this precise feature, or something very similar, will be available in the next release of ZBrush. So you might get it in a few days…
If you see the first video they released about ZB4R7 they talked about this…
Ok thanks
I am not sure if the transpose line will follow as you describe in the next release, they didn’t mention that part, but I would really like it if the transpose line actually updated as you use it to rotate or move and it followed the part you are posing.
