Center or Pivot of object
Hey guys,
I’ve got an OBJ file, when I import it into zbrush, it’s center is shifted to the left. When I import it into Softimage, it’s OK. When I send it to SI via the GoZ, in SI it’s OK. What can be wrong??? Is the real pivot position omitted when the object is imported? Only bounding box is considered?
Cheers
Jester
Look under preferences> Import and export. There are some options. HTH.
I ran into the same issue again. Unfortunately, there is no option for this.
